Saltar al contenido principal
Sexta generación del iPad, lanzado en marzo de 2018. Disponible en Wi-Fi y LTE con opciones de almacenamiento de 32 y 128 GB. Cuenta con una pantalla Retina de 9.7 "y un chip de fusión A10 de 64 bits.
Preguntas 20 Ver todo
Home Button doesn't work after iPad 6 screen replacement
I have been repairing electronics for years. Never had any issues with iPads until recently, home buttons stop working after digitizer replacement. There is no damage to the home button or the cable or anywhere. Anyone else having this problem?
Or have found a solution?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
It could just be an alignment issue, is the metal part of the home button bracket (which is the contact for the button) aligned with the center receiver of the home button?
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
No, it even makes the clicking sound and everything. Even when I install a new button, still doesn't work.
- de
The clicking sound is not an indicator of anything. Try to align it better with the bracket. I had this issue as well last week.
- de
Look at the back of the home button. There should be a tiny black dot in the center of the switch. If all you see is amber that dot has fallen of and the switch will not work when installed.
Puntuación 0
Añadir tu respuesta
minnabeezy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,030
