Let me add my problem also….thanks for a suggestion.
My Samsung LCD has a flickering backlight problem. If the backlight menu settings are actived, the bottom half or third of the backlights start to flicker (each second or so). The panel is fine. TV is opened and I can access the back side easily.
I need to know: can I check the backlight LED strips without fully removing the panel , so to pinpoint the issue to either the backlight LEDs, or the power supply ?
Replacing the power supply would be easy if I knew its the faulty piece….
Tearing down the full panel is more of a hassle…
Any advice ? Can the power wiring that goes to the LED strips be checked for correct voltages , are there any technical data sheet for a UE60F6370 around ?
Tjanks
