Saltar al contenido principal
Una SSD, o unidad de estado sólido, es un tipo de dispositivo de almacenamiento que utiliza una memoria flash basada en NAND para almacenar datos.
Preguntas 52 Ver todo
Apple 2016/17 Apple Blade SSD 5GA 34+22 Pins NVMe Converter / adapter
Hi I am looking for a adapter that allows me to plug in a 2016/2017 non touch bar ssd drive to usb or usb-c to read and test drives externally. I cant find anything online
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
3 comentarios
Did anyone ever find a solution. I’m having the exact same problem. The Apple 22 + 34 pin SSD used in the newer 13” Macbook Pro Fn models.
- de
Did anyone ever find a solution. I’m also having same problem. Looking for an adapter for for Apple 22 + 34 pin SSD.
- de
Same problem here. I'm searching thoroughly, but no luck yet. :-(
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@porterk74 - Please review my answer here Access to files on SSD drive.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
@rmmorshedbk - Sadly, the market for anyone to make a case to hold the SSD is just not there. OWC would have been the only one to have offered one and I don't see anything on their web site.
Apple has moved on to fully soldered SSD drives in the newer models.
- de
A little spendy at $60 USD. If it’s for a 128GB SSD then probably not worth it. Could find a comprable (size/performance) for less with greater aesthetics.
https://digitalintelligence.com/store/pr...
Puntuación 1
1 comentario:
How does this Tableau adapter connects to PC/Mac? Is it SATA, or USB?
- de
Añadir tu respuesta
kirk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 81
Todo El Tiempo: 4,548
