Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El JBL Charge 3 se reconoce por su distintiva cubierta de altavoz tejida y detalles de goma. Se lanzó en 2016 y cuenta con un diseño totalmente resistente al agua, 20 horas de tiempo de reproducción y conectividad Bluetooth.
Where can I buy a port bay replacement?
I’ve recently broken off my MicroUSB from the port bay. Any idea where can I buy a whole new port bay?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
If your JBL Charge 3 speaker’s ports are no longer working, see the JBL Charge 3 Ports Don’t Work problem page for possible problems and solutions.
Fue útil esta respuesta?
Puntuación 1
@raoulvanbalen It's not that common for aftermarket parts manufacturers to duplicate a printed circuit board design unless there is a big demand for that as a replacement part, and it doesn't look like the port bay circuit board has met that criteria.
At this point your best bet to buy a port is to keep an eye on eBay for someone who is parting out a speaker. One seller seems to do that a lot, but unfortunately they are out of the particular card you want for your speaker.
ORIGINAL JBL Charge 3 Parts Main Board/Speaker/Battery/Charging AUX Port etc.
On the other hand, if it's just the micro USB connector itself that's damaged and the circuit board itself is still intact, you could, with a little bit of soldering skill, replace just the port. There are lots of places that sell just the connector like Amazon, eBay and AliExpress. Here's one example from Amazon.
Amazon.com: 2X Micro USB Charging Port Replacement for JBL Charge 3 Bluetooth Speaker : Electronics
If the soldering is out of your comfort zone, you may be able to find a local repair shop that can do the work; for them it should be a simple task and hopefully shouldn't cost too much.
Puntuación 1
EBay https://www.ebay.co.uk/itm/285239247127?...
Puntuación 1
The answer from Arielle Sampson is not satisfying. Where can people actually purchase a port bay?
Since the Micro USB port is nearly broken, we think we need a replacement. So where can people get that?
Puntuación 0
Añadir tu respuesta
Misel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 32
All Time: 931
