Fit bit exclamation and no charge
Fitbit doesn't show anything but an exclamation mark. When off the charge port it is dark.
Es esta una buena pregunta?
The exclamation mark usually means one of two things. You either waited too long to recharge your Charge and the battery is fully depleted. Or else an error occurred during a firmware update, in which case restarting your Charge and leaving it plugged in afterwards will cause the update to resume and complete.
How to Reset : Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display. This indicates that it has restarted.
Fue útil esta respuesta?
Thank you so much !! It is charging!!
no button on the charging cable.!
Is there any way to have the Fitbit work again if I waited too long to recharge and battery is depleted?
No button on versa 2 charging cable.
Mine has battery sign with exclamation mark2023, always charged ok. Now can’t sync as won’t find watch
check this video it may help you to using your galaxy fit '''https://www.youtube.com/watch?v=g223JepU...
don’t forgot to say thanks
My fit bit charge to is your not exclamation sign when plugged in to chargeMy fit bit charge to is your not exclamation sign when plugged in to charge
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 103
Todo El Tiempo: 41,559
2 comentarios
it still shows the exclamation mark with the battery sign. I am trying to change profiles. please help!
thanks.
- de kasie emeralda
https://www.youtube.com/watch?v=g223JepU... check this out
- de kannan shop
