Saltar al contenido principal
El Samsung Galaxy J2 es un teléfono inteligente Android que se lanzó en noviembre de 2016.
Preguntas 101 Ver todo
J2 Samsung -2 vibration then restarts on it's own
My samsung J2 phone started 2 weeks ago to restart on it’s own. This week I updated my software but it didn’t stop. I also tryed reinserting battery.
It goes like this. First vibration, in aprox 5 sec 2nd vibration and it restarts.
It doesn’t matter how much battery I have or what apps are/or not running
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @camelia2 ,
Try starting the phone in safe mode and see if the problem still occurs.
If it doesn’t occur when in safe mode, then the problem is being caused by a downloaded app. The trick is to find out which one. You’ll have to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall. When the problem is no longer there, the last uninstalled app was the problem. Start with the ones installed or updated at about the time the problem first started.
If it still occurs when in safe mode, try performing a factory reset to see if this resolves the problem.
>>>>>>>Before performing the reset, backup the phone using the phone’s backup feature.<<<<<<<
When you have completed the backup, factory restore the phone using the phone’s factory restore feature.
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the phone to its’ factory default condition or last updated condition. That is why it is important to backup first.
When the restore has been completed, check if the problem is still there.
If it is still there you have a hardware problem.
If it now works OK, using the backup that you made earlier, restore the phone to what it was before you started using the phone’s restore feature.
When the phone has been restored, check that it still works OK.
If it does then the “reset” has resolved the problem
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Camelia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 848
