Saltar al contenido principal
The Durango was marketed as a sturdy truck-based SUV designed to hold up to seven passengers and tow up to 7,500 lb (3,400 kg) when properly equipped.
Preguntas 17 Ver todo
How do I go about r and r ing a bad freeze plug?
My sons 1998 Dodge Durango had a cracked radiator. We have replaced the radiator and started refilling the system and there she blows, a steady stream of fluid coming from the front most freeze plug on the passenger side of the block. Is there an easy way to remove one of these? I remember wrestling with one years ago and I seem to remember it being a pain in the a__!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Drill a pilot hold get a slide hammer thread in a course stud grab it with the sh chuck and give it a few wacks if that doesn't do it hit it on the lip and wack it in turning the plug sideways in the hole yank with vise
Fue útil esta respuesta?
Puntuación 0
I use a screwdriver that I can hit with a hammer, and drive a hole in the middle, they pry it out.
https://www.youtube.com/watch?v=lqHVNqwK...
Make sure you use a little RTV when you re-install it.
Puntuación 0
Añadir tu respuesta
alan.thomas65 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 31
