Saltar al contenido principal
Traditional analog twin bell alarm clock by LaCrosse. 6.5 inches in length, 4.5 inches in width, and 2 inches in depth and 8 ounces in weight. Gold metal case, luminous hands and hour dots, analog quartz movement, and clear glass lens.
Preguntas 7 Ver todo
Detached wires on analog twin bell clock
Hello,
my twin bell clock fell off the shelf and 3 wires got detached. Can anyone help me put them back into appropriate spots? There is one hanging from the bell part; another one from the battery piece, and the last one from the little compartment in the middle. Thanks for your help in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Ania ZygZak  right now it looks like you are only supplying + to the clock. I would connect the wire marked with the green arrow to the clock mechanism. It is hard to see but it appears as if there was solder on the 2nd connector on the mechanism. See if that gets the clock going. I would need another view from the side (red arrows) to see if there are any solder pads and where the far right wire connects on the bell motor. there appears to be some writing on the mechanism any chance you can let us know what it says. I suspect a maker and model number which might help
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Ania ZygZak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 870
