Temperature to remove IC
Hi there!
What’s the best temperature in celsius degrees to remove the Wi-Fi IC and, after that, solder the new one?
Thank you!
Es esta una buena pregunta?
Hi there!
Thank you!
There isn’t a set recipe for doing micro-BGA work with a hot air station. Everyone develops their own style and methods based on the station they have and whether or not the temperature is actually calibrated or not. Generally speaking, I use 380C on my hot air station (Hakko FR810) and I adapt the time spent heating a component to the type of IC I am working on, the proximity to sensitive or critical IC’s, the possibility of underfill and component density surrounding the IC in question.
I would certainly start wth a lower temperature setting to pick at the underfill and then work on removing the IC at a higher temperature.
Fue útil esta respuesta?
Understood!
I'll try something around 380ºC because I think that my soldering station isn't calibrated yet (Yaxun 881d), but first I'll start with a lower temperature.
Thank you!
360C to 380C is the temperature most often seen in the repair community.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,662
