Saltar al contenido principal
Esta cámara instantánea de Fujifilm ahora cuenta con un cuerpo más delgado y liviano que las revisiones anteriores. El Mini 8 ayuda al fotógrafo alertándoles sobre la apertura recomendada. También tiene un modo de flash High-Key que ayuda al fotógrafo a obtener retratos suaves para una apariencia deslumbrante.
Preguntas 355 Ver todo
Fujifilm Instax Mini 8 polaroids coming out blurry
hi guys my polaroids are coming out very pale. the black is not very vivid, ive tried playing around the modes too
either its too dark or its too light for the same image.
does the film expire? and does it affect the image quality?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
if the film has not been stored in a stable environment ie too hot or too cold this can cause the film to produce images that may appear washed out or pale. This effect may also happen if you are shooting photo’s in very hot or very cold conditions.
If the image is blurry you may be too close to the subject; these cameras have a small range for focal distance at the close up-something like 45cm-1m, check you have the right setting for close up or long distance and vice versa.
Overly light photo’s generally mean it has been overexposed (too much light or too long an exposure). Check the door is closed fully and not leaking light on the film. Expired film may produce faded photo’s too.
I’d try a new pack of film, be careful when loading it, and see if the same photo results.
Good luck
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Sukeerti estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 56
Todo El Tiempo: 9,337
