Why wont my starter rope pull?
Hi, so I started a DIY mini ATV project with a 49cc pocket bike engine about a year ago. I started it once, then it sat in my garage for a while. The other day, I tried to start it again. When I tried to start it, the pull rope came out a bit then got stuck. I tried to pull harder, but it wouldn’t move. I took the pull start assembly off, and it pulled fine. The starter flywheel turned when I used a tool to push it. But as soon as I put the pull start assembly back on, it wouldn’t pull. Does anyone know what is wrong and how I could fix it?
Thanks in advance!
P.S I am only 13, so if the fix is obvious don’t judge. I don’t know much about this stuff.
Es esta una buena pregunta?
7 comentarios
My ole man is having the same thing Happen to him He pulls and pulls and pulls Messing with the flywheel a little then it let's him pull a tiny bit then somewhat and freezes again please please someone help how can we get it to start… . Anyone b
- de LISA GALLUPS
I had a new CT-200 Coleman shipped to my home. Assembled, said it didn’t come with oil but, it did have oil in it. Topped off oil, added fuel, turned on gas, choked it & its locked up!
- de Steve
I have a coleman ct200u I never had something such a nightmare starting. If your lucky you might get a good pull right away if not I have to pull easy 2 times because its locked 3rd time I usually get a pull. Then if your lucky and it starts prey it didn't foul the plug again. I have a 212cc gokart its so smooth starting 1st pull
- de Juliet Oldshield
So my Coleman is now junk
- de Steve
i had the same exzact issue
- de Wyatt Baker
Mostrar 2 comentarios más
