Saltar al contenido principal
Guías de reparación y soporte para automóviles y SUV fabricados por Mitsubishi Motors Corporation.
Preguntas 20 Ver todo
Mitsubishi Endeavor Driver side window controls won’t work
Hey i have a Mitsubishi Endeavor 2006. The driver side window switch won’t open or close any of the car windows. The switches on every other door can still open their respective windows. I bought a new switch and installed It but that didn’t fix the problem. I’m thinking It could potentially be the wire connected to the switch. I wanted to see if anyone thinks this could be the issue or if it’s something else. Also how to go about fixing It. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
The ground wire going from the door to the main body is loose or broken.
To much to go through to replace specific wire, you could run any new wire from door to body & see if its good.
Hold down the lock button on the driver & passenger door at same time, roll down driver window. All 3 buttons at once.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
mlise785 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 293
