Screw of the mainboard broken. what can I do? (repasting thermalpaste)
Can i get it out with a dremel or the notebook brokes then? ;( pls help me
Sorry for my bad english. ( im german)
Es esta una buena pregunta?
There are different options depending on the screw damage. I would advise you to share some photos of this problem with us - perhaps we will be able to figure out a better solution than Dremel or drill.
But answering your question, yes, Dremel can help.
If the head is stripped, use Dremel cutting wheel to make a slot in the center of the head and remove it with a regular slotted screwdriver.
Like here: https://www.youtube.com/watch?v=DD7jYf8A...
Or if the head is completely broken, or part of the broken screw is stuck inside, you can try to drill it out using the drill bit for metal, just keep the following in mind:
Fue útil esta respuesta?
my screw looks lkke this: help me what can i use https://imgur.com/gallery/3T2F9Zc
but its more broken then on the photo bcz i tried and tried :/
i have a dremel but what type of cutting wheel should i use
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 110
