Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Epson Artisan 1430 es una impresora fotográfica de inyección de tinta a color.
My printer is not recognizing the OEM cartrigdes
My Epson 1430W is making a werid problem. I had a failure with my printhead and motherboard, I replaced both. The problem was that it was not recognizing the cartridges. But after the replace of those parts is still giving me the failure.
It recognizes when I put 1 by 1 of the cartridges, but on the 6th it gives me the error. I checked the fuse F1 and its good. The board and the printhead are brand new
Es esta una buena pregunta?
Puntuación 1
3 comentarios
It does not allow me to do the update, it sends me an error. Any thoughts?
- de
If you can post the error message it will be helpful. On printer display or computer etc.
- de
I am having the same problem . I have exhausted everything I know. looking for any ideals
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I fixed my non-functional Epson printer with this procedure….
https://epson.com/support/updating-your-...
This may or may not correct the problem you are seeing.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Did not help me still same problem
- de
Imagen
there is a fuse on the main board fuse no.2 it is broken replace it and the issue will be solved.
it is caused by incorrect manual head cleaning.
Puntuación 0
Añadir tu respuesta
aemleal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 611
