Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Tarjetas de almacenamiento Micro SD fabricadas por Samsung Group.
256GB SD card is read as 268GB and cannot mount?
Hi,
I have a Samsung EVOPlus 256GB microSDXC card that I bought new, and formatted (Apple HFS on MacBook Pro 13” 2015 with MacOS 10.14.2) and was able to use for a few days fine (although it seemed a touch slow).
Now my computer is unable to mount the card (“This disk is not readable'“), although it shows up in Disk Utility as a greyed out internal physical volume with a capacity of 268.44GB. I’ve tried First Aid, but it says there’s an “Invalid key length”.
The stuff (about 3GB worth) on here hasn’t been backed up anywhere else yet, so I really want to try and save it all.
Any advice or tips? I don’t even understand how the system suddenly decided the card gained an extra few gigs!?
Thanks for any help you can give,
H
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
FYI - High Sierra & Mojave both auto format flash & SSD drives with APFS file system which is different on how HFS+ works. For compatibility I strongly recommend you reformat the flash to exFAT so it works with your phone or camera.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
You’ll need to give a file recovery app a try like Data Recue 5
After you salvage your stuff you’ll want to re-format the SD back to exFAT. You really want to leave it running exFAT.
Fue útil esta respuesta?
Puntuación 1
maybe try mounting it with terminal
diskutil list
then find your sd card in the list and type
sudo diskutil mount diskXsX
where x is the disk and partition number
Puntuación 1
Just try to plug it in other mac with lower system if its readable, so you may know if the sd card has the problem or your system. because i have an issue with my external HDD cannot be read in 10.14.2 but readable in 10.11 and 10.12.
Puntuación 0
Añadir tu respuesta
SD Card Issue estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 57
Todo El Tiempo: 2,194
