Switching a Ipad 5 logic board to a Ipad air
I understand that these Ipads are both the same but will my Ipad 5 logic board line up exactly with the screw holes and cables. Meaning…will they reach and fit?
Es esta una buena pregunta?
No, even though many parts are compatible between the two, still many aren’t, and those changes are because of different logic boards between the two units. You’ll need to get a logic board that matches your model.
Fue útil esta respuesta?
Even I had the same question but I would like to add a lil bit... what if the housing n logic board of a IPad 5 is used n the rest of the parts from iPad Air?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 236
1 comentario
Basically this is a 'Square Peg, Round Hole' problem. The logic board is don't interchangeable.
- de Dan
