How to I factory reset tablet supersonic sc-77tv
How to I factory reset tablet supersonic sc-77tv does not pass from android
the key combination does not work
Es esta una buena pregunta?
Firstly hold down the Power button, until your device is turned on.
Then from the home screen open Menu and choose Settings.
Select Backup & Reset and tap Factory data reset.
Choose Reset device and select Erase everything to begin hard reset operation.
Well done! Your tablet should restart itself right now.
Second method:
Start by swtiching off the device by pressing Power button.
Press and hold Volume Up + Power key for a couple of seconds.
You can release held keys when you see an Android Logo on the screen.
To enter the Recovery Mode hold down the Power button for a short while.
Afterwards from the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
Tap "yes" to confirm if you are 100% sure you want to clear all your data.
Press Power button to enter option "reboot system now".
Cogratulations! The hard reset has just been performed.
answer via - https://www.ifixit.com/User/1837590/Bob 2017 How to I factory reset tablet sc-1022KB
Fue útil esta respuesta?
it does not go beyond the logo
so option 1 is not possible
not either enter the recovery menu
with that key combination
well your going to have to tear it down and hope pulling the battery will do the trick.. ill dig more in the mean time
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 2,195
