Saltar al contenido principal
Una lavadora de Maytag con una tasa baja de satisfacción del cliente y una tasa alta de fallas.
Very Loud In Spin Cycle
The washing machine works great, but is super loud during spin cycle….can hear it on other side of house with the door closed to laundry room.
Any recommendations? Thank you.
Matt Gibson
Es esta una buena pregunta?
Puntuación 1
2 comentarios
What type of noise is it producing?
- de
The actual spinning. It’s not a grind noise, or a screech, it’s not overloaded.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.
Fue útil esta respuesta?
Puntuación 2
It’s the bearing that’s making the noise not the belt. It’s common in these washers, need to either order a kit and replace it yourself or pay someone to do it.
Puntuación 1
Añadir tu respuesta
Matt Gibson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 8,302
