Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado en 2014, el Lenovo C560 es un ordenador todo en uno con una pantalla de 23 pulgadas y compatibilidad opcional con pantalla táctil.
Computer Wont Boot Up
I have a Lenovo c560 all in one and recently I had been running into some trouble regarding its booting. Sometimes it will boot, and sometimes it wouldn’t. Eventually it stopped booting completely and would just be a black screen with a feint clicking sound so I decided to do some research, and saw online that changing the hard drive cable would work so I tried this and it worked initially but then wouldn’t work again. Can someone please help as I need for work. Thank You
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
I dont know how to use the usb if the pc wont load. Is there a key I press on startup because nothing shows on the screen at all at any point
- de
Press F2/10/12 ESC or DEL imediately after you turn on the pc. It's either of those which will get you in the BIOS or bootmenu.
- de
when starting it would go on but show automatic repair then lead me to the advanced options
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
If the computer won’t boot and there is a faint clicking sound, then your HDD hard drive may be failing. HDD hard drives make a clicking sound when they are about to permanently stop working. You may have to get a new hard drive soon.
If there is data on your hard drive that needs to be saved, please save it immediately. If you cannot salvage the data, perhaps a technician can do it for you.
Fue útil esta respuesta?
Puntuación 3
Might be your HDD dying.
  • Try resetting the BIOS to default settings and see if that works.
  • Get a Windows 10 installation usb stick and run startup repair
  • Install Windows on a fresh HDD and see if it boots from it
Puntuación 1
Añadir tu respuesta
Anthony Johnson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 1,772
