Battery display turned yellow
Battery isn’t holding charge as well three days ago battery display turned yellow rest of the screen no change
Es esta una buena pregunta?
It sounds like your phone is in Low Power mode. Got to Settings-Battery and there should be a slider to turn it off. I believe the phone will go into Low Power mode automatically if the charge is very low. Hope this helps.
There may also be a problem with the battery.
Fue útil esta respuesta?
I found yellow battery display indicates high power usage if something not turned off it then goes to low power mode and yes I think it’s time for a new battery
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 43
