Saltar al contenido principal
A1150 will not charge. Can one replace the charging circuit?
I have a used A1150 (eBay) and it has never been able to charge at all. I followed all the troubleshooting guides from Apple's tech pages and went to my local Apple tech store. They switched the Magsafe and swapped the battery. Their battery worked fine but the Magsafe charger still did not work (it holds a very dim green light when attempting to charge). They said it probably was not the logic board but the actual charging circuit. What part(s) would I need to replace the charging circuit? can one replace the charging circuit without soldering?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Do you mean to say they swapped the left i/o board? (the part with the magsafe board)
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
yes, the charging circuit should be on the left I/O Board, you can find the repair instructions here - replacing it does not involve soldering.
Fue útil esta respuesta?
Puntuación 1
They only switched the Magsafe adapter not the left I/O board. Sorry for not qualifying that. @rab777hp
Great tutorial @bac. i will grab a few tools and find a replacement left I/O board. Thanks!
Puntuación 0
Are you sure it's not the battery? The computer end of the Magsafe on this model of Macbook Pro glows red when the battery is depleted and green when fully charged.
Puntuación 0
My bet would be the Left side I/O board. Not difficult to replace, but parts getting hard to come by!
Puntuación 0
Añadir tu respuesta
Steve 10 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 5,996
