Saltar al contenido principal
El JBL Charge 4 es un altavoz resistente al agua con Bluetooth que, además, funciona como cargador portátil para teléfonos inteligentes. Se lo puede identificar por su número de modelo: CHARGE4S.
Preguntas 20 Ver todo
JBL Charge 4 speaker suddenly stops playing sound
My JBL Charge 4 bluetooth speaker was working fine until it suddenly stopped playing sound (even the ones it plays when it turns on, off, etc.). I don’t know what could’ve caused this since I don’t use the speaker on max volume. Speaker was charged and it connects fine, hasn’t gotten extremely wet either.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
11 comentarios
Jbl started having severe noise distortion and all of a sudden just stopped playing or making sounds at all. No power up or power down sound even though it seems to be connected to my phone. It is fully charged and brand new. Any advice?
- de
Same problem with mine, though no noise distortion before it fell silent suddenly. It was playing normally, then suddenly nothing. No power up or power down sounds, no connect sounds though it is connecting. Nothing. Pretty much still new. What’s the problem here?
- de
For the charge 4, the reset buttons changed to the play/pause button and the bluetooth button
- de
anyone got a solution for this? my Charge 4 just stopped producing any sound for no absolute reason, even the on/off sound is not played now, it connects normally but totally silent. factory reset didn't solve it. any help?
- de
Same for me - brand new and stopped producing sound out of nowhere - what a crap
- de
Mostrar 6 comentarios más
Agregar un comentario
9 Respuestas
Respuesta Más Útil
Try powering on yourJBL Charge 4 first and wait for the LED indicator to turn on. Then try holding down the play/pause button and the volume up button up to 20 seconds and that should factory reset your device. Then try again and see if it makes sound.
I personally have a JBL Xtreme and I’ve had similar problem and factory reset fixed mine. Hopefully it works for you too.
Fue útil esta respuesta?
Puntuación 1
7 comentarios:
Tired that it didn't work for my charge 4
- de
Same problem, tried factory reset but still no sound. I need help
- de
Same for me, no sound....
- de
GREAT now my JBL won’t even turn on after doing those steps!
- de
Ok so this is the wrong combination for the Charge 4, mine also didn't reset and stopped turning on. I've finally found that to fix it again, you have to plug it in so the power lights up. Then hold Bluetooth and play buttons until it switches off. Then you can unplug and switch on as normal. That was an hour of stress I didn't need
- de
Mostrar 2 comentarios más
Mine started working somehow, i pressed both the power and connect+ button together. While keeping these pressed, press the play and volume up. I somehow got mine back to life.
Try this again and again after putting into charge and removing it from charging.
Puntuación 0
1 comentario:
Download the JBL Connect app. Pair the speaker with your phone. Select upgrade speaker.
- de
Download JBL Connect app. Pair Bluetooth speaker. Select Upgrade speaker.
Puntuación 0
1 comentario:
Worked like a charm although I don't understand how and why I was able to to upgrade my speaker off of my phone.....
- de
mine did the same thing after falling. I took it apart and found the part the red arrow is pointing at was dislodged. I pushed it back in and it started working again but only when I’m pushing down on it. Not sure how to keep the downward pressure with glue.
Puntuación 0
I had this problem and in my case solution was surprisingly stupid. Apparently I was connected to speaker on 2 devices. On pc, which was the music source, and on phone, which I used to browse reddit. Eventually I was stumbling on videos on reddit, and even without sound when you start looking at them, speaker stops playing sound on pc. So basically try checking for when exactly music stops and if it’s somehow related to what you are doing at the moment.
Puntuación 0
My JBL charge 4 was playing music then all of a sudden it stopped playing it won't turn on but when I plug it in the power button light turns on but don't do nothing I tried pressing the power button plus volume up button and nothing
Puntuación 0
1 comentario:
Did you ever get the audio working on your charge4? Mine has no audio also.
- de
Yes is not up to a month
Puntuación 0
2 comentarios:
Yes and is not up to a month what do you think
- de
I did the reset thing
- de
JBL charge 4, ic sound problem
Puntuación 0
1 comentario:
Same problem.
- de
If hard reset doesn’t work, disassemble it( check youtube) the take a look if one of the wires is disconnected. This was my case, works fine now. I imagine the assembly process is flawed if this problem is common. I never dropped my speaker or nothing too.
Puntuación 0
Añadir tu respuesta
SpeakerDude estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 37
Ultimos 30 días: 174
Todo El Tiempo: 48,252
