Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Don’t see ‘charge battery’ screen once phone shuts down at 1%
Replaced battery a while back now, realised after it shuts down automatically once it gets to 1-2% charge, usually when i go to turn it back on without chargin, It shows a ‘plug charge cable in’ screen when you try and turn the phone back on, where as now it tries to boot again with the white apple logo screen.. gets about 10 seconds in showing the white screen on, and turns off again.. then if i try to turn it on again it goes into a boot loop with the white screen.. until i just get a flicker of white every few seconds.. then once i plug it in to a charger, it will white screen, turn off, then white screen and finally boot..
isn’t a major issue at all, just wanted to know what is going on, have tried a sleep button and home button reset (holding for 10 seconds until apple logo) as well as charging till 100% switched off, then home sleep reset again and running it down to 1%.. but still the same..
thanks for any help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Considering that this started after a battey change I would be inclined to think you possibly have pry damage around the battery connector, there is a swi filter Knoked off that commonly cause this,
Or secondly your initial issue may not of been tha battery. You may have a faulty tristar ic that can also cause the symptoms.
You will need to get this looked at by a board level tech.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Adam Bloor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 40
