Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Lenovo IdeaPad 110S-11IBR fue lanzado en septiembre de 2016 por Lenovo.
Charging port replacement or part number
I’m just going to copy and paste this from the reddit post I did.
Hi, I was given a Lenovo Ideapad 110S-11IBR netbook as I will call it and the charging port is broken. I did some research and this was a common issue with this device. Well apparently no one is able to locate a charging port for it. Googling the issue with this device you come across this link (https://forums.lenovo.com/t5/Lenovo-Idea...) and you can see how weird this port is. I see someone said they re soldered the middle pin back to the piece it worked. Well I'm not good with soldering and would rather replace the whole port to make sure that it is good. Does anyone have any idea on what I can do? I am looking into a replacement motherboard but they are at least half the price of a working unit on ebay and the charging port no one has been able to locate. I would really like some help on what can be done. If I can get this device fixed i'm going to get a nice M.2 ssd to upgrade the storage and fix the broken plastics on it.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
@dudefoxlive Just for completion sake, by now these DC jacks are fairly easy to obtain from places like this Looks like the J91120 from the previous answer, is the manufacturers part number and hard to find by that number.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Ah ok thanks. I believe this can finally be marked as an answer. Wonder why it took so long for people to find this.
- de
@dudefoxlive yes, some places make it so difficult to find parts. I think part of that is related to proper terminology. DC In Jack is usually easiest to find. Anything else depends on how it was listed. Best of luck with your repair.
- de
I know that this is 3 years later, but I wanted to write an answer here for others that might come searching this way.
The DC JACK that I pulled out of a 110s-11ibr that I was working on has the part number J61124.
I have ordered a replacement jack from Amazon which has the part number J91120 and it appears to be identical.
Puntuación 0
2 comentarios:
This is strange but i cant find anything in amazon with that. Can you send the listing that you used?
- de
This is what I bought :
https://www.amazon.it/dp/B091CMDSYS/ref=...
That part is made by a manufacturer called Zahara. But as the other responder mentioned, these are quite easy to find now. You can buy them quite cheaply from AliExpress, if you don't mind the wait.
By the way, I can confirm that the replacement jack that I bought worked perfectly in the laptop.
- de
Añadir tu respuesta
Dudefoxlive estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 629
