Saltar al contenido principal
Lanzada junto con el AirPort Extreme base extention, esta variante de disco duro equipado ofrece 802.11ac de velocidad en una cápsula del tiempo NAS (almacenamiento conectado a la red).
Preguntas 54 Ver todo
I can no longer access the 3GB drive anymore how do I open it
I can no longer access the 3GB drive in the Time Capsule. The WiFi router is still working OK and the Time capsule is listed in the left column of finder windows but when I try to connect to the drive via WiFi or Ethernet I just get a message that there is a problem connecting. I want to try removing the drive to test it separately to try to save the data and maybe replace the drive but…
How do I open the time capsule?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
It’s pretty easy, you just open up the bottom, disconnect some cords, and pull it out (basically). iFixit has a guide with full details you can follow.
Fue útil esta respuesta?
Puntuación 1
Do keep in mind the drives format is unique to the TC (it is not natively mac readable). If you really need to save the data you'll need to transfer to another A1470 capsule. Thats assuming the drive is still good.
Your other option is to use a data recovery app like Stelalr
Often times the power supplies go
Puntuación 0
Añadir tu respuesta
frank estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 97
