Saltar al contenido principal
Una SSD, o unidad de estado sólido, es un tipo de dispositivo de almacenamiento que utiliza una memoria flash basada en NAND para almacenar datos.
SSD failed to restore
APFS failed to invert. OSS Error 22
Update (02/14/2019)
Mac mini (Late 2014) running Mojave (10.14.3).
I was able to clone the drive with the Carbon Copy Clone app. I'll know today if it was successful after I install it.
Thanks Jonah
Es esta una buena pregunta?
Puntuación 0
1 comentario
What is the exact Mac system you are using as well as the drives specs.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Success! The SSD is up and running.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Disk Utility no longer works with APFS file systems for restoring/cloning devices. Using a Time Machine backup or Target Disk Mode on an old computer are the only ways to transfer data.
Puntuación 1
3 comentarios:
Don't know why you're talking about Disk Utility here as we still have no idea what the system is. Until we get that you're just shooting in the dark.
FYI: The cloning options are no longer present in the latest version of Disk Utility
- de
Are you restoring the drive with CCC or Disk Utility? I just want to double check where you’re actually seeing this error.
- de
Error was with disk utility. CCC worked perfectly. Up and running!
- de
Añadir tu respuesta
Kenneth Hillman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 602
