Showing a grey screen with "serious error has occoured".
The screen shows a serious error has ocoured, contact support in 20 different languages. This is after connecting the blu ray drive and installing a new HD.
Es esta una buena pregunta?
Matthew Miller, did you restore the file system? it is my understanding that the PS3 does not boot from your hard drive as a computer does. It has flash memory that stores all system files and system firmware updates that you get when the PS3 updates. Just in case you need the Service manual, download them from my file server so you can take a good look at the PS3 to see what is going on.
How to Access Playstation Recovery Menu
"1. Turn off Playstation3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Supported Features of 2.50 Recovery Mode
The current Recovery Menu supports:
Restart System:
Restarts the PLAYSTATION®3 System.
Restore Default Settings:
Reset all system settings back to default.
Restore File System:
Checks for corrupt/missing system files.
Rebuild Database:
Rebuilds the OS for the PLAYSTATION®3.
Restore PS3 System:
Fresh restore; Deletes everything and starts from Scratch.
System Update:
Update the PLAYSTATION®3 System"
Of course I do not mean to insult your intelligence or your skills, just wanted to make sure that we are all on the same page....Good Luck.
Fue útil esta respuesta?
We're on same page now. Did the restore and got the fatal error. Working on the update.
Update ended in error 8002F14E.
When I do any of the steps listed it gives me an error screen in 20 languages.
Found this on llama "What's happening is that the PS3 is running in Nand flash mode. The Nand has NOT been flashed until this phase is complete. Your PS3 is checking your entire system hardware for faults. If it finds one, then you'll get that 8002F14E code (or similar) and it won't complete until you fix the hardware problem it found. Depending on where in this process it stalls (in the loop % of completion), can indicate where the possible failure is.
Generally if it stalls in the 60-70 range, this indicates a problem with the BluRay (even a dirty lens or bad diode) player in some way. It can be the disc insertion sensor, the main ribbon cable or simply a loose connection. But until you fix it, it will continue to loop in update mode. If it's in 40% range of completion, it can be anything from a bad or loose hdmi connection to fan malfunction, possibly the hard drive (try re-seating harddrive), Power supply (voltage variance or loose connections), WiFi board, USB connector problems, etc!
more on here http://forums.llamma.com/viewtopic.php?f...
Posted as an answer for someone else but relevant to your situation now:
Error 8002F14E [General Hardware Issue] Problems:
It could be simply locked in an update loop. Your PS3 can be saved. Recheck all connections and cables and/or re-seating your hard drive.
Warning!!!
Whatever you do don't format the hard drive you used in the Update Flashing of your PS3 if it's looping. If you do, it could keep it from ever finishing that update. This is why Sony wants you to send in your hard drive with your PS3 for repairs. In case it's related to this update process. But the actual flashing of PS3's Nand doesn't complete until it reaches 100% and reboots.
What's happening is that the PS3 is running in Nand flash mode. The Nand (one adjacent to Super Companion/south bridge) has NOT been flashed until this phase is complete. Your PS3 is checking your entire system hardware for faults. If it finds one, then you'll get that 8002F14E code (or similar) and it won't complete until you fix the hardware problem it found. Depending on where in this process it stalls (in the loop % of completion), can indicate where the possible failure is.
(for this reason, if somebody wants to sell you a PS3 that is locked in the loop, make absolutely sure that hard drive is included. If not, you will be buying a brick)
If you are out of warranty, then you must decide to on if you are going to open your PS3 up or not. Consider if you are any good at this sort of stuff or not. The PS3 is not hard to tear apart, but you must map things out to know where everything goes back. Inventory your PS3 condition before the update in your mind. Did you have any problems with over heating and shutdowns. Was your PS3 reading all disc types? Any problems accepting discs or ejecting discs? .....and for sure, if you are having ANY hardware issues, then DON'T RUN or give permission/accept the Update until you have these issues resolved!
If you decide to pull your PS3 apart. Do it with care, keeping track of all the screws and where they go. Use a heat gun and razor to carefully remove the warranty sticker, so you can replace it after repairs are done. Make sure you know how to remove and re-insert ribbon cables properly. The BD player needs care in removal. Such as if your model has the tiny fine wires running from the control board to the sensor located on top front. BE EXTRA CAREFUL OF THESE WIRES AND PLUG. DO NOT simply pull the plug from it's socket by the wires. Use finger nails or tweezers to carefully jockey this connection from it's socket.
The BD lens can be cleaned w/o separating the black housing parts. By simply removing the metal case cover, followed by pulling the white magnetic part in the center over the disc rotating motor on top of the black top half. Under toward the back is the laser. Use cotton que-tips and alcohol. Gently first wipe the lens in a circular motion one direction, then the other. Now you would use a dry Que-tip to dry it off with using same technique. USE LIGHT PRESSURE ONLY!
If you decide to pull the whole assembly apart to either clean or replace the diode/lens assembly, then make sure to take note of how things are when you pull it apart and watch some videos on YouTube before trying this. You don't put it back together properly, it may take the disc, but not spin properly and not eject the disc after getting a fail to read it. This can be prevented by observing how you replace the black top assembly. Just prior to setting it down (w/ BD player disc opening facing you), tilt the back of the part toward you, so that the white loose gear part slides down toward the front. You will know it's right by looking at the top, where you'll see two small observation ports (holes). One small w/ one larger one just above it. If you see solid white through these holes, then it's wrong. There is only one white part on the reverse side that is loose. If it didn't slide down on the tilt, then slide it down before replacing it!
That's about it for now. Remember to be patience and use care in this process before you panic! :D ....and you just may have your PS3 running again!
-*-EDIT-*-
I also Found this in an old forum post:
First let me tell you what had happened. Error 8002f1f9, 8002f1f0 and 8002f042
My son got Modern Warfare 2 for x-mas and when I attempted to load it, it required a Firmware update that was on the CD. From what I understand, it copies the update to something on board.
Well, after it got to about 55%, it gave an error code 8002f1f9. I removed the HDD during the update the second time and it got to 99% and stopped. After a long while, it gave error 8002F042. Of course Sonys online error tool didn’t have these.
I called Sony and after trying to get me into the Hidden Recovery Console, not letting it come up, Sony told me that I would have to send it in. It would cost x amount of money I dont have. The PS3 is close to a launch version and I have had no issues with it until this update. Then of course Sony tech tried to say that it was something that I did, maybe a power issue. The PS3 is on a UPS so that’s not it. I have been in the IT field for over 10 years and this guy started explaining that he knows that a Firmware update did not cause this.
All the PS3 was doing was booting into the system update and giving an error every time. Not letting me do anything but watch it error and start in the update mode over and over. Our thoughts were to clear the FLASH and loop with JTAG and load an older FIRMWARE version. But I was finally able to get into the Hidden Recovery Menu, formatted the HDD, told it to do a System Restore and it also gave an error, this time with a Serious error (no other details provided).
The FIX:
Thinking of anything to un-brick the PS3, I was about to give up. I took it apart thinking to get it ready for the JTAG fix BUT… Here is what I did instead first. I removed the battery. A little, on mine at least, blue standard battery. After that, we shorted the 2 pins on the board that the battery was connected to. DON’T SHORT THE BATTERY ITSELF. Anyway, we got the idea from working on PCs. To clear the BIOS or BOOT password and settings on some systems, removal of the CMOS battery and short the 2 battery PINS. Anyway, I left the battery unplugged and hooked everything back up to at least turn it on. It then started the system setup after a short update. It did update the version to 3.14 so I think that it was just finalizing the install. But there was nothing hanging the update at this point and started the initial system setup. Issue resolved.
I put the COD game back in and though it now requested a SOFTWARE update instead of a FIRMWARE update, it took it without any type of issues. My formally bricked system is now working and playing fine. If your PS3 is bricked by Sonys failed attempt of any update, try this first before you toss it or sell it. Then again, if you don’t want to pay the cost Sony wants to look at it and it is bricked, it will not hurt you to do so. There are many places online to find instructions on how to take your PS3 apart, all I am doing is telling you what got my PS3 out of the Update loop that it was in. I was told that I should offer this fix for sell, but I will not. I will accept any and all donations through PAYPAL (ID jared9901) though if this helps you save your system.
NOTE: This should only be used if your system is OUT OF WARRENTY and you have no intention of sending it back and giving your money to SONY. I cannot and will not be held responsible for any thing that happens if you try this fix. Please note that as long as you follow the directions on taking your PS3 apart correctly and the shorting of the battery, NOTHING will happen to your system other then a possible CHEAP fix. Just don’t be in a hurry taking it apart or skip steps. I have provided you with the fix, the idea of searching for instructions on how to take it apart and etc. All I am telling you is how I fixed the issue that SONY caused and refuses to admit too.
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 2,379
Did you restore the file system? it is my understanding that the PS3 does not boot from your hard drive as a computer does. It has flash memory that stores all system files and system firmware updates that you get when the PS3 updates.
- de oldturkey03
Its all good oldturkey. That first part of getting to the recovery menu was very helpful. This is my first PS3 so Im still learning the tricks to access and what and where everything is at. I've done PC's and older laptops before.
- de Matthew Miller
