iMac 24" bad power supply - maybe capacitors?
Hi
We’ve a 2009 iMac 24” 3.06 Core2 Duo. It’s been sat on the shelf for a couple of years, but dug it out for my daughter to use and it has been working well for a couple of months - until this week. Apparently it had switched itself off overnight a few times, but switched on OK. Now it doesn’t switch on OK. We get the first LED when plugged in, then the second lights lights up for a couple of seconds, then the third and fourth lights flash on, fans briefly spin and a tiny chime, then all LEDS off. If I leave the RAM out it lights up 2 LED then just beeps for as long as I leave it. I thought this ruled out the logic board. I removed the display and still same behaviour.
Now I’ve removed the power board I can see three swollen 16v 2200uF capacitors (c205, c206, and another) - is this likely to be the problem and worth swapping them and trying again? The used Power boards on eBay are pretty expensive for a not guaranteed fix - and are also 10 year old. But I would like to get the computer running for a bit longer as it was working fine! I can’t see any cold joints on the board, but may have a closer look while waiting for the caps.
I’ve tried the easy fixes like SMC and PRAM resests and new button battery.
Anything else I’m missing?
Thanks!
Es esta una buena pregunta?
