charging cord will fall out
When I place the charging cord in it will not lock in the port.
Es esta una buena pregunta?
Have you tried using a different cable? It sounds like the small clips that hold the cable in place may be damaged.
Fue útil esta respuesta?
Charging ports experience a lot of traffic in plugging and unplugging. Most likely in this situation the charging port has become “worn out” in that the connection may have experienced some slight bending or rather become “warped” and now can no longer hold the cord in place properly. The best fix for this would be to replace the charging port and the connection will be as it should. However in some cases the repair cost can outweigh the cost of getting a new device. Hope this helps.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 43
