side by side samsung water dispenser will not stop shooting water
I have a Samsung rsg257aars side by side water dispenser will not stop dispensing. I heard that filter not sealing can cause this. I replaced the filter and it work fine for a few days then started again. I also tried a Samsung brand filter ($50 from Lowes) still no luck. I am thinking about replacing the filter housing next but I wanted to check here before shelling out another $70. It does the same thing without a filter.
More info. The ice dispenser works fine so that ruled out the microswitch. I even tested the microswitch separately with a meter. works perfect,
I look forward to hearing from some more experienced folks out there
Es esta una buena pregunta?
Any update? We have the same issue. Replaced the water filter and was ok for a week only. Repair man wants $500 for the water valve but says he isn't sure it will correct the problem.
- de mskrisham@hotmail.com
My ice and water dispenser will not stop. Water or ice goes constantly. I had to turn off the water to the fridge. I want to replace the water inlet valve (approximately $100 from parts store) but was informed part # DA62-04027C is no longer being made by Samsung! You can't get it. Any suggestions?
- de N Thomas
Mine just randomly starts shooting water sometimes even when I'm asleep. I also have a thick layer of ice under the refrigerator drawer. The only way I can stop the water is by turning the water supply off, unplugging it and letting it reset. I have no clue why there is ice under the freezer drawer. Help!! roger120275@yahoo.com if you have any ideas please email me.
- de Roger Kincaid
