Saltar al contenido principal
El teléfono insignia de Samsung con stylus y el sucesor del Note8, lanzado en agosto de 2018. Cuenta con una pantalla de 6.4 "y hasta 512 GB de almacenamiento a bordo.
Preguntas 91 Ver todo
Touch screen recognizing finger only s pen on note 9
I was replacing a screen on a note 9 and when I switched the motherboard and other components to the new screen and powered it on the phone would not recognize me touching it with my finger so I tried the s pen and it worked fine so then I switched everything back to the old screen thinking that it was just a defective part and it still wasn't working. I tried cleaning off the connectors for the screen and resetting the phone and neither worked. Any help would be greatly appreciated. Thank you in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I thought so too but I put all the components back onto the original screen and the touchscreen didn't work on there anymore and I also tried different screen and didn't work on there either
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
probably just a faulty screen
S pen is a completely different part of the display to the digitizer, it’s the large rectangle flex near the lcd connector.
unless you buy the screen from samsung or from a new phone they are all refurbished, so probably just a dud screen
Fue útil esta respuesta?
Puntuación 1
Did you ever get this fix? I'm having the same
Puntuación 0
1 comentario:
Also, would something like that be under warranty?
- de
Añadir tu respuesta
Poop mcgee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 2,113
