Saltar al contenido principal
Possible to semi-rebuild a Dell Inspiron laptop and make it faster?
I have an old Dell Inspiron 1720, still working, just isincredibly slow. I’ve backed up everything that I had on it, haven’t been actively using it for several years.
Is it possible to semi-rebuild the laptop with new parts that will make it run better/more efficiently/less loudly? (fan used to go constantly even after pulling it apart and cleaning it)
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
You haven’t given any of your current specifications but the RAM can be upgraded to 4GB DDR2 PC2-6400 (2x2GB - a pair is better than one 4GB) and the SATA hard drive to an SSD. Just noticed that it has an option for a second hard drive so your old one could be used for extra storage space.
For example:
https://www.crucial.com/usa/en/compatibl...
but other sources are fine.
It has a dual core processor which is good.
It can also be upgraded to Windows 10 for free if it has a legal Windows 7 or higher.
Newer drivers will also help.
So yes can be ‘semi-rebuilt’ as you put it. DELL has manuals for it on their website.
I would not try to play any games on it but would be fine for work.
Please ask if you have any more questions.
Re: Fan
The fan going constantly could be a software issue such as a driver but again upgrading RAM to 4GB, a SSD SATA drive and finally upgrade to Windows 10 would probably do the trick.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ashleigh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 376
