Sharp Aquos LC-37D43U Televsion
Hi I have a LC-37D43U tv. The power works with green light in front of the tv and the backlight, I think also work. What should I check if backlight does work. When I power the tv I see dots of light. When I turn on the power there is no picture but I have a glow. The audio also works well and can hear everything clear. The tv control, by pressing any function does not work. Also with the flashlight test, it does not show anything. I did open the back of the tv and would like to try to fix it myself before giving up and buying a new one. What should I do or try to verify as the problem?? Do you have a video explaining what to change or test before?? Thank you. Frank Bilotto
Es esta una buena pregunta?
Frank, do you still have this tv, it is an upgrade to an older version different model number. I have the same as you, can we work together?
- de Duane Donaldson
I had a similar issue with my Sharp Aquos and determined that the tuner was blown.
I was able to bypass the tuner by connecting the signal through the AV jacks. Problem Solved.
- de Michael Shaw
