Saltar al contenido principal
Guías de reparación y soporte para OnePlus 5T, un teléfono inteligente Android con una pantalla AMOLED de 6.01". Lanzado en noviembre de 2017. Sucesor de OnePlus 5. Número de modelo: A5010.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Probably needs the digitizer cable reset. Desmontaje de OnePlus 5T here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Fue útil esta respuesta?
Puntuación 0
Original screen folder Amoled
Puntuación 0
Añadir tu respuesta
Liam Mooney estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 1,777
