Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2690 Ver todo
Can’t answer incoming calls
Have a weird one have an iPhone 6s works great but when a call comes in screen stops working can’t answer and phone will continue to ring until I do a hard reset. I have taken it apart and cleaned it no water damage have replaced the screen install a new battery.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Fix for iPhone keeps ringing but screen freezes: I know this is an old thread, but maybe it will help someone else. This happened on my Mom‘s iPhone 6. It started after I enabled Announce Calls for “Always” for her (under Settings/Phone). I turned off Announce Calls and the problem was fixed. The feature works on my iPhone 8 so it also could be a software update issue.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
The person that post about the announcing calls. Thank you soooo much my phone as driven me crazy but you helped fix it. I had tried everything. I turned off the announce calls and the phone is working again.
- de
Tried this, no luck. Yikes!
- de
I tried this, and it worked!!!!
Before the I phone 6 was ringing and I could not answer calls and front screen would freeze. only way out of it was turning phone off then on again .
Also on outgoing calls I could only call out once before locking. would have to turn phone off then on again.
Text messaging worked the whole time
- de
I would check and make sure there is not a software update that is missing. Sounds like a software issue. Go to setting ->General->Software Update and See if it shows and update that is needed. Best of luck.
Puntuación 0
Añadir tu respuesta
Patrick Dean Willard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,832
