Saltar al contenido principal
En el 2004 North American International Auto Show, Nissan presentó un Pathfinder completamente rediseñado para el año modelo 2005.
Preguntas 15 Ver todo
Why my 2012 Nissan Pathfinder loses brakes completely on the road?
Hit a pothole 8 months ago and lost use of brakes entirely for a few minutes, Eventually brakes recovered after continuous pumping of brake pedal. Since then it has done it several times while driving without even hitting potholes or any uneven surface on the road. Have serviced four wheels and replaced Master Cylinder and it still happens.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I would have a mechanic check your break lines, and maybe a search to see if there is some sort of sensor for your ABS
Fue útil esta respuesta?
Puntuación 0
1 comentario:
There are four sensors, one on each wheel. Then there is the ECU which controls the ABS breaking process. Nissan Dealer has checked all of that but has revealed nothing out of the ordinary. When this problem happens not even the brake malfunction light on the dashboard lights up…. Poltergeist?
- de
Añadir tu respuesta
Julio Lynch-Lorca estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 330
