Can the accessory hose be replaced because the nipple broke
The nipple on the accessory hose valve broke off and I would like to replace it. How can I open the machine to replace this part?
Es esta una buena pregunta?
It is near impossible to replace that is why there is no replacement part. The end that attaches to inside machine goes to a enclosed reel. So you have to remove the reel and disassemble it both jobs looked very involved. The other end is very hard as well. I came up with a very easy fix you will need to order part #FA2000-000 from foodsaver. You will need to cut the hose about a inch from the canister on the new part and the old part. Now you need to splice the two parts with a small tube. I used a 1/4” delrin tube I cut the flared end off and it fits inside both hoses to join them together. Any questions ssaammss@aol.com
Fue útil esta respuesta?
I noticed the black hose hangs up when pulling it out you might try to bevel with a sharp knife. I used a wrap of black electric tape over the joint
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 33
Todo El Tiempo: 1,681
