One tail light does not work
One tail light does not work - replacing bulb did not correct the problem.
Es esta una buena pregunta?
If the running light works but is dim, have someone hit the brake. If the dim light goes out, you’ve got a bad ground. Check the metallic connection from the bulb through the socket into the body or wiring. Rust right at the socket is pretty common, scrub it shiny, put a light smear of grease to suppress later rust. You can try taking a piece of wire, hold one end to the socket contact and find bare metal with the other. A dim running light will brighten up to normal confirming bad ground.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 226
