2.5ghz DG card, replaced LCD panel from a 2.8IG card, all are mid 2015
So I attempted an LCD replacement from a mid 2015 BTO integrated graphics card, replacement Lcd was to be installed in my mid 2015 dual graphics card.
All the connections were the same nothing was different, except after powering on the display there is no light, although you can see the desktop folders icons and etc.
Nothing leads me to believe that the display was defective in any way shape or form as it works in the previous machine MBP.
My question is are the displays different for the discrete versus the integrated graphics card?
Of course I did all the necessary resets, SMC PRAM!! Ugg
Otherwise the machine works perfectly on an external display, It also recognizes the retina display but it won’t allow me to adjust the brightness.
Update (12/27/2018)
A small drop from 6”... lol
Display went dead but everything else works.
Update (12/28/2018)
So here’s to images I found I’m not sure of the location of this fuse, The zoomed in image is of my logic board, The other is from a thread I found here.
Any help is greatly appreciated!!
Es esta una buena pregunta?
To start with the display assemblies are the same across the mid 2015 IG & DG models.
Can you tell us a bit more here on why you are replacing the display.
- de Dan
