My aux input broke!
I was using this, and after pulling out an aux cord, the 3.5mm jack popped off of the board. It is an SMD component, how can I fix this?
Es esta una buena pregunta?
Ok, I fixed it. The aux input had popped cleanly off of the board, but the contact pads were left behind. I had to take off the rubber casing (with my hands/fingernails), and unscrew the bottom bay. It is a little tough to get the main PCB out of there, but not too hard. Disconnect the battery (I used a toothpick to push it out from the top of the connector, since it was tightly pushed in), and place the jack back on the board, with the pins aligned. I carefully soldered it back on with a fine, curved tip (Hakko T18-BR02). I replaced everything after verifying it worked.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 115
