My soundlink mini won't charge, the battery indicator is flashing red
when i try to charge my soundlink mini the battery indicator light just flashes red and won’t charge.
Es esta una buena pregunta?
First generation Bose SoundLink Mini released on July 1, 2013. The device weighs 1.5 pounds and has a Bluetooth range of 30 feet.
hey kevin,
in most of these cases where either the battery no longer with us or the power PCB bust. to find out which it is you will need to open the speaker using guide: Reemplazo de la batería del Bose SoundLink Mini
and then using a multimeter to see if the battery can hold charge if the battery is actually dead then you will have to get a new battery. otherwise see if there is anything unusual with the speaker using this guide:
Bose SoundLink Mini Button Switch Circuit Board Replacement
i wish you good luck
-M
Guía
Dificultad:
Fácil
5 minutes
Guía
Dificultad:
Moderado
10 minutes
Comentarios:
I discovered after several attempts to charge it via the Multi-function button, I simply replaced the cable with a new cable (was my hubby's shaving cord) and VOILA!! The Bose mini 2 charged without even using the cradle.
100% charged --working fabulous!!!
- de injoycards
Have you checked the connector port is clean and undamaged/loose?
Also check that the cable/plug is undamaged- not sure if this charger has an indicator light that it is receiving power?
Try a known working charger (the pin connector on these is fairly common).
Ultimas 24 horas: 29
Ultimos 7 días: 195
Ultimos 30 días: 1,080
Todo El Tiempo: 26,944
This fix worked , thanks
- de Malcolm Ryan
