Introducción
Follow this guide to replace the the button switch circuit board on the Bose SoundLink Mini speaker. The button switch circuit board is located deep within the body of the speaker. It may be necessary to replace this part if the buttons on the speaker no longer work properly. Make sure you have the necessary tools and follow the guide step by step to replace this part.
Qué necesitas
Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
16 personas más completaron esta guía.
12 comentarios
Hello
Where I can buy circuit
Yes were can we get the replacement part? ?
Hi sonny,
did you find this part ? (the first circuit board)
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
