Saltar al contenido principal
La actualización de abril de 2014 de los paquetes MacBook Air de 11" actualizó los procesadores Haswell i5 e i7 de doble núcleo y aumentó ligeramente el rendimiento de la batería.
Preguntas 98 Ver todo
MacBook Air shut down suddenly and won't turn back on
My laptop was working at 11.30 this morning perfectly fine with 16% battery. I went to put it on charge on a plug I have used before with no issues. Came back to it at 1.30 and the whole thing is completely dead. No ‘charge battery’ image coming up on the screen, the power cord isn’t lighting up green or orange (tried it on another laptop and it worked fine, tried a different power cord that I checked works and no lights), no dings or beeps or whines.
I have tried all of the Shift+Fn+Ctrl+Cmd and power button combinations that have been said before, but none are working.
I am hesitant to open up the back as I have no proper knowledge of the inner workings of a computer and don’t want to damage it further.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Removing back plate is the only way to get further with troubleshooting and it’s necessary to get a hint on what’s the problem. I’d suggest to try disconnecting the battery connector from the logic board and then plug in the magsafe, your mac should start on its own if the issue is just battery related. If magsafe still shows no light something is probably shorted or dead in the logic board or the I/O board, that might be replaced as first repair attempt.
Fue útil esta respuesta?
Puntuación 3
I had the same problem and I FIXED IT.
I looked up online How to fix it but nothing worked.
this morning, I woke up and I was mad that my laptop wouldn’t open up and I continuously taped shift , control, option and the power bottom… it just turned on after like 10 seconds of that!! I was shocked. Hope this helps!!
Please subscribe to my channel if this helped you… it would help me if you subscribed
Go to YouTube and search cpl robben
thank you so much
Puntuación 1
Añadir tu respuesta
Sarah Bennett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 106
Todo El Tiempo: 7,725
