Saltar al contenido principal
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Preguntas 34 Ver todo
best glue to attach LCD to body
Hi,
I’ve seen some reviews on best glues to attach LCDs to Digitizers, but I couldn’t find any for attaching LCD to body.
I used double sided adhesive tape and it did fine for some time but after a while it loses it’s stickiness and so the LCD gets lifted up from the body and dust sticks to the tapes and so the process repeats again.
I’d appreciate if you could share your skills.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Make sure the glass and frame are completely clean and then use tesa tape
https://www.mobilesentrix.com/tempered-g...
Other people swear by 3m primer 94
3M Primer 94 Pen 0.2oz | Vinyl Car Wrap Application Tool (5 Pack) https://www.amazon.com/dp/B00HVEW9ZW/ref...
Fue útil esta respuesta?
Puntuación 2
1 comentario:
If You want to get best vinyl wrap then I will suggest you to buy https://www.vinylfrog.com/vinyl Wrap.
- de
T-7000 adhesive in a tube. this is the black version, just a tiny amount around the edge, turn the phone over and weight with a heavy book while the adhesive sets up.
Puntuación 0
1 comentario:
yes adhesive in a tube. this is the black version, just a tiny amount around the edge,
You can check https://www.ahijoy.com/collections/adhes...
- de
Añadir tu respuesta
Mahdi Mohammadi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 452
