Saltar al contenido principal
El teléfono insignia de Samsung con stylus y el sucesor del Note8, lanzado en agosto de 2018. Cuenta con una pantalla de 6.4 "y hasta 512 GB de almacenamiento a bordo.
Preguntas 91 Ver todo
note 9 sim pick into the mic hole
Hello, a similar situation to the one described here : Microphone could be damaged? but with the samsung note 9.
A sim pick tool was introduced into the microphone hole by mistake. Consequences? On the mic? On the waterproofness?
Is the physical arrangement the same as for s7 edge (in the example above) ?
Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
As long as you didn’t go too far the mic should be fine, but the IP rating would technically probably drop.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
Thanks for your answer! How exactly could I test the mic? Since it's not the one used in conversation... More, I have left the phone for 20 min under 10cm of water. No problem.
- de
If it isn't the one used in convo, you should be able to test it by recording a video
- de
use samsung voice recorder in interview mode.
- de
I poked both the mic and another hole near the sim slot by mistake. All seems to be wrong. Could there be any damage to the one near the sim slot. And what is it for. Can I help?
Puntuación 0
1 comentario:
Working* not wrong :)
- de
I have heard that no harm will come to the mic. Worst case you have pushed into the rubber seal.
Puntuación 0
Añadir tu respuesta
No Azerty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 2,777
