Saltar al contenido principal
Un altavoz portátil y resistente al agua para exteriores diseñado por Bose para una cobertura uniforme desde cualquier ángulo. Bluetooth, comandos de voz y conexiones auxiliares permiten múltiples opciones de conexión para hasta 12 horas de uso. Una versión liviana del Bose Soundlink Revolve+.
Preguntas 19 Ver todo
Speaker is totally dead
Hello
My speaker is dead , the battery charging light flashes on and off but if you disconnect from the charger there are no sings of life
chris
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
1 comentario
I have the same problem can someone help me with that my speaker is just 30 days out of the warranty period
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Chris,
I’ve had this problem too. Finally got it sorted by updating the firmware. You can download an app from BOSE onto your computer and then re-launch the website you downloaded it from. It took about 5 mins to update and works perfectly again!
https://btu.bose.com/
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
This worked for me on two speakers that I thought were finished, thanks!
- de
I also have the same problem. totally dead just a flashing red light. and after updating the speaker firmware back to normal life. but after 2 months it turns off again with a flashing red light. please the solution. thanks
- de
...but how can I update the firmware if the speaker is TOTALLY DEAD AND WILL NOT CHARGE? The speaker refuses to recognize the USB when I connect it to computer.
- de
@mr_butty check (and possibly change) the battery first. That way your speaker will have power to accept an update of the Firmware through the USB connection.
- de
Añadir tu respuesta
chris ryan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 5,351
