Saltar al contenido principal
A budget-friendly Axon Pro, released fall 2015.
How to re-programmed the ZTE Axon?
May phone stopped working long ago i want to restart it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
Cómo quitar el patrón
- de
Agregar un comentario
1 Respuesta
I believe you can hold the “volume up” button and “power” button simultaneously for five seconds. If done correctly, assuming the phone is charged, from there, you should be able to press volume up and down button to enter the boot menu. Try the “reboot” option to see if the phone is still operational so that you may recover pictures, contacts, etcetera, or continue using the phone. If this fails, go back to the boot menu and try the “update from cache” option. Then, if that fails, try the wipe/reset option. Good luck.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
The problem with my device is that, after I did as you said in the answer above it used to show me that 'unfortunately the phone has stopped' and I press OK it showed me 'unfortunately the fingerprint has stopped'. what is the solution?
- de
Añadir tu respuesta
derouiche djamel din estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 213
