How to fix a bent back of ipad min?
Accidentally bent the ipad min a little bit. It now gaps a little bit on both side. How do I get it to refit the ipad mini?
Es esta una buena pregunta?
At minimum, remove the digitizer and LCD, then use a tool such as the gTools PanelFormer Pro to coax the frame back into straightness, then put the LCD and digitizer back in.
Fue útil esta respuesta?
That is a delicate tool to use to fix aluminum housing, I would just slowly bend the frame and straighten it out with bare hands (with digitizer/LCD and logic board removed of course).
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 554
