Saltar al contenido principal
Adaptador de corriente alterna magnético de segunda generación para productos MacBook, lanzado por primera vez en 2012. No es compatible con sistemas de generaciones anteriores Disponible en versiones de 45W, 60W y 85W.
Preguntas 23 Ver todo
Is there any known way to test Mag-Safe adapters
I’d like to be able to tell if I have a bad Mag-Safe adapter or if I need to look at the computer. I know they fail, as I have a box full of failed ones. It would be nice to tell first if my power source is working correctly. Anybody know how?
You would think there would be some type of testing software.
Es esta una buena pregunta?
Puntuación 5
2 comentarios
There has to be a way to test them with a multimeter.
- de
You can check out https://en.wikipedia.org/wiki/MagSafe#Pi... and test the pins with a meter. Note how it says that the V+ should give full voltage with a 40 kOhm load.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I just use a DC-In Board which I wired in a .5 watt 50 Ohm resistor for a load and then wired in test leads for both the power and the one-wire comm connection. Most of the time I just depend on coconutBattery output.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
mayer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 49
Todo El Tiempo: 7,062
