Saltar al contenido principal
Released in 2015, the Asus G752VL-DH71 is a 17-inch gaming laptop. It is often referred to by the shorter name G752VL or G752.
Preguntas 9 Ver todo
Laptop is dead after dissasemply
Hello,
Most probably I ruined my laptop but just want to get your ideas if any.
I dismantled my laptop because I was hearing a noise inside of it whenever I was moving it. I found out that the BIOS battery did fall of as it was being hold with a tape……….
When I added some tape I reassembled my laptop but does not work any more. I hit the Power on button but no lights, no fans. Its Dead. I am sure that I have put everything back in place. I have opened multiple laptops in the past. The only strange I noticed is that when I was disassembling it I noticed the back leds of the monitor to open instantly and then stop again…… without a proper reason. The power cable was unplugged but the battery was unfortunately on. Any tips/ideas to verify if the Motherboard is dead?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Probably there must be a loose connection while assembling make sure all connections are tight and check every part ram power supply etc which is disconnected are connected properly and no corrosion inside it.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Sokratis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 10
Ultimos 30 días: 10
Todo El Tiempo: 226
